skip navigational linksPJRC
Shopping Cart Checkout Shipping Cost Download Website
Home MP3 Player 8051 Tools All Projects PJRC Store Site Map
You are here: 8051 Tools Development Board Circuit Board Search PJRC
PJRC Store
8051 Board, $79
LCD 128x64 Pixel, $29
LCD 16x2 Char, $14
Serial Cable, $5
9 Volt Power, $6
More Components...
8051 Tools
Main Page
Software
PAULMON Monitor
Development Board
Code Library
89C2051 Programmer
Other Resources
PC Board Artwork, Rev 5
Here is the artwork required to etch the printed circuit board. You can buy bare boards, but if you like etching circuit boards, here are the high resolution images you will need. This board uses a modest number of vias, and has 8 mil (0.2 mm) traces, with 8 mil spacing and many wires connect on the component side, and the ICs are close enough together that it is very difficult to solder the top layer with a socket. Four ICs require PLCC sockets, so insert pins soldered both sides are needed underneath these PLCC sockets.
This circuit board artwork is distributed in the hope that it will be useful, but it is provided without any warranty, not even a warranty of merchantability or fitness for a particular purpose.
Component (Top) Side Solder (Bottom) Side
thumbnail image, top side thumbnail image, top side
Download 600 dpi TIFF ImageDownload 600 dpi TIFF Image
These TIFF images are exactly 600 DPI. When printed, the board size should be 6.00 by 4.01 inches (15.24 by 10.185 cm). For proper printed results, use a high quality graphics manipulation software package that allows you to exactly control the printed output resolution. On Linux, the GIMP works very well, and it's free software. Many linux distributions include it installed by default, or available on the cdroms. On Microsoft Windows, Photoshop or similar packages are your best choice. Saddly, Photoshop is a lot more expensive than the GIMP (which works just was well).
Bare Board Available From PJRC
Here is a photo of a bare board that can be purchased from PJRC.
image of the circuit board
Dimensions
mounting hole dimensions
8051 Development System Circuit Board, Paul Stoffregen
http://www.pjrc.com/tech/8051/board5/pcb.html
Status: finished
Suggestions, comments, criticisms: <paul@pjrc.com>
