Shopping Cart
Home | MP3 Player | 8051 Tools | All Projects | PJRC Store | Site Map |
You are here:
PJRC Store
![]() ![]() | Search PJRC |
MP3_DISPLAY | LCD Display For MP3 Player, 24x8, with Pushbuttons and Cables | $42 |
The $42 display package includes all the items needed to use the display with the MP3 player: the display board, the small board with 12 pushbuttons, a ribbon cable attached to the display board, and a 4 pin cable to connect the pushbutton board to the MP3 player. The display board comes with the 1.0 display firmware loaded, so it is ready to use with the MP3 player by just plugging the 4 pin cable into the LCD port on the player.
This LCD kit includes the LCD with a programmed firmware chip installed, and a ribbon cable attached to the connector on the LCD board. The pushbutton board and 4 pin cable are also included.
The only assembly required is to plug the ribbon cable connector into the pushbutton board (the polarizing notch prevents backwards connection), and then to connect the pushbutton board to the mp3 player using the 4 conductor cable (also polarized to prevent backwards connection).
