Shopping Cart
| Home | MP3 Player | 8051 Tools | All Projects | PJRC Store | Site Map |
You are here:
8051 Tools
128x64 Graphical LCDUpdate: This 128x64 Graphics LCD can be used with Teensy 2.0 and Teensy++ 2.0, using this library code and Teensyduino.
The above image was created using this code:
lcd_init(); // init the LCD, clear the buffer
print_to_lcd = 1; // printf_fast to LCD buffer
buf_set_font(font_timBI24);
buf_set_position(6, 0);
printf_fast("128 x 64"); // first line: 128 x 64
buf_set_font(font_7x13B);
buf_set_position(25, 30);
printf_fast("Graphic LCD"); // second line: Graphic LCD
buf_set_font(font_4x6);
buf_set_position(0, 58);
printf_fast("Font sizes from large to tiny...");
for (i=4; i<120; i+=20) {
buf_line(i, 42, i+20, 55); // diagonal line
buf_line(i+20, 42, i+20, 55); // vertical line
lcd_update(); // copy buffer to LCD
Example Code (for 8051 processors)Example code (beta test version):lcd_128x64_07.tar.gz lcd_128x64_06.tar.gz
Fonts (beta test):
Diagnostic Utility: Accessing The LCD (lcd_driver.c)Only two simple functions access the LCD hardware.
lcd_init()
lcd_update() Off-Screen Buffer Operations (lcd_buffer.c)To actually use the LCD, you need to compose the image in the off-screen buffer using these functions, then call lcd_update() to display it.
buf_set_position(x, y)
buf_set_font(font)
buf_putchar(ch)
buf_draw(shape_ptr)
buf_pixel(x, y)
buf_line(x1, y1, x2, y2)
buf_clear() Connections To 8051 Board
How to connect to the 8051 board: LCD 8051 Notes: --- ---- ----- 1: Vss Ground (pin 1 on LCD connector) 2: Vdd +5V (pin 2 on LCD connector) 3: Vo Connect to 5K POT wiper 4: D/I A1 (pin 4 on LCD connector) 5: R/W A0 (pin 5 on LCD connector) 6: E E (pin 6 on LCD connector) 7: D0 D0 (pin 7 on LCD connector) 8: D1 D1 (pin 8 on LCD connector) 9: D2 D2 (pin 9 on LCD connector) 10: D3 D3 (pin 10 on LCD connector) 11: D4 D4 (pin 11 on LCD connector) 12: D5 D5 (pin 12 on LCD connector) 13: D6 D6 (pin 13 on LCD connector) 14: D7 D7 (pin 14 on LCD connector) 15: CS1 A2 16: CS2 A3 17: Reset 10uF cap to ground, 22K resistor to +5V (see schematic) 18: Vee Connect to POT side (other side to ground) 19: A +5V 20: K Ground
As an alternative to using a 5K pot for the contrast adjust, you can use higher impedance values with a PNP transistor. A 2N3906 or almost any other small general purpose PNP transistor should work, allowing any pot value between 10K to 250K. Update: Pin 17 can be connected directly to +5 volts. The 22K resistor and 10µF capacitor are not necessary. Extensive testing has shown this LCD works fine without a pulse on its reset line. |
