9 photos of the Mk I player. Rather than wait for everything to fall
into place (USB/Ethernet, State control etc) I decided to get use and
enjoyment out of the player while I have it. The sound is super thru
my Harmon Kardon Amp and Tannoy Mercury speakers.
I have a laptop 6.5 GB IBM Travelstar (half full only!). It is
connected to the 3.5 HDD connector via a 3.5->2.5 IDE cable. This has
a PC (12v/5v) power connector on both ends - one on the cable and the
other on the power cable drawing 5v from the MP3 board. To load MP3s I
just disconnect the 3.5 ide connector, unplug the PC power connector
and plug it into the PC IDE and a spare PC power connector. A bit
kludgey but its quick and easy.
Once I sort out my USB problems I will go that route.
I used normal hardware store perspex - cut out holes using a drill for
the buttons and the Display mounting screws. I mounted the board
itself on high standoffs to give it a better look. I heated the
perspex with a blow torch and bent it back. This stuff is very hard to
work with and this was my 3rd attempt to mount the board onto it.
Cracks, overheating and poor drilling led to the demise of the other
attempts ;)
Other things I did were to solder the display connector and the LCD
connector on the board to make it easier to fit stuff on the board.
That's it.
Mk II will have a more professional perspex appearance, USB, IR remote
and EL backlight. I'll post those as they happen.
