USB Cable with 5-Pin Mini-B Plug
| Discontinued | CABLE_USB_MINI_B | Standard USB Cable with 5 Pin Mini-B Connector | $4 |
This standard USB 5-pin Mini-B cable is needed to connect the Teensy to your PC or Macintosh.
Mini-B works with Teensy 2.0. Mini-B does not work with Teensy 3.0 (requires Micro-B).
This cable is 4 feet (1.2 meters). It uses #24 conductors for the USB power, to enable projects using the maxium 500 mA USB current to work properly.
