USB Cable, Mini-B to Standard-B Panel Mount Adaptor
CABLE_USB_PANEL |
USB Cable, Mini-B to Standard-B Panel Mount Adaptor |
$12 |
| Inventory Status: | In Stock |
| Last physical count: | Aug 23, 2010 |
This short cable allows mounting Teensy or Teensy++ inside an enclosure,
with a sturdy standard B type connector. The Teensy is protected from
excessive force applied to the panel mounted connector.
Why is this cable $12? It's made in the USA by Newnex, and it's manufactured
in smaller quantities since it is not a cable used with nearly all USB devices
with the mini-B connector.
