Shopping Cart
| Home | Products | Teensy | Blog | Forum |
You are here:
OSU8 Microprocessor
Single Bit Full AdderThe 16-bit ALU uses 16 of these full adder circuits, in a ripple adder configuration. ALU16 maniplates the carry bit between its second and third instance of this adder, when it executes the functions that compute branch targets.Because these adders are used in a ripple carry in ALU-16, (as they are also used within ALU8's adder), the addition is the slowest portion (timing critical path) of OSU8's circuitry. For Xilinx, this should probably use the fast-carry logic within the Xilinx CLBs, or custom CMOS this should probably be a Manchester carry or carry-lookahead type adder.
