39F512 Flash ROM Chip
Discontinued | 39F512_PLCC | Flash ROM Chip | $8 |
This 39F512 is supported by PAULMON2 v2.1. It requires only a single 5 volt power supply. By using this Flash ROM chip, you can add permanent storage for download programs. It is also possible to use the chip for data logging. This chip supports erasure of the entire chip at once, or in 4k blocks. This is the same chip used on the 8051 Development Board, Rev 4.
Related PJRC Project Pages
- Dev Board, Detailed Description -- also include a link to block erase example code.
- Dev Board, Schematic and Parts List
- PAULMON2 8051-Monitor Download
- PAULMON2 Documentation, Hardware Requirements
