Teensy-LC USB Development Board
Discontinued | TEENSYLC_PINS | Teensy-LC USB Board, with Pins Soldered | $15.85 |
Update: Due to limited chip supply for Teensy 3.x, PJRC is discontinuing pins soldering for all Teensy 3.x products. As we are able to get the chips, we'll continue making these boards without the pins soldered.
Teensy-LC delivers an impressive collection of capabilities to make modern electronic projects simpler. It features an ARM Cortex-M0+ processor at 48 MHz, 62K Flash, 8K RAM, 12 bit analog input & output, hardware Serial, SPI & I2C, USB, and a total of 27 I/O pins.
Teensy-LC Technical Details are available here.
Teensy-LC maintains the same form-factor as Teensy 3.2, with most pins offering similar peripheral features.
