Display Communication Protocol
PJRC discontinued this product in February 2009, and has
not sold these LCDs since that time.
PJRC has never sold this LCD
via eBay.
If you purchased a similar 24x8 LCD on eBay, that eBay merchant very likely
used the open source code published by PJRC,
perhaps with their own modifications.
They are not affiliated with PJRC. Any
adaptor hardware provided with such LCDs is not made by PJRC.
Please contact the seller for technical support.
PJRC publishes free technical information and open source code in the hope
it will be useful. However, PJRC does not provide technical support
for other merchant's products, even when they have utilized free
code published on this website.
This page documents the communication protocol used by the 24x8
LCD supplied by PJRC. Most of this information is specific to
the firmware provided by PJRC.
If you puchased a LCD from some other source, it may have different
firmware, or even a chip that does not contain usable code. PJRC
sells a
firmware chip
that can be used on LCDs obtained from other sources.
About The Display Board
The display circuit board is
JW-002, from
Earth Computer Tech. The back side of the board has an
80C32 based system with 64k of RAM and a socketed EPROM chip.
The clock speed is 11.0592 MHz. The display has two KS0108B
controller chips. While these are graphical LCD controller
chips, the display itself has grouped the pixels into 5 by 8
pixel blocks, which limits its use for bitmap graphics.
Earth's page has the connector pinouts and some other information
about the board. Perhaps Earth will provide a schematic and
other info on their page in the future. PJRC does not have a
schematic for the JW-002 board... we obtained these boards
from Earth, so we do not have schematic, layout, or other
design data (for students who "need" a schematic, we probably
never will since we did not design the board).
Our firmware was written based on reverse engineering, and
everything that we know about the board is documented in the
firmware source code.
When used with the PJRC MP3 player board, the JW-002 is
connected by a ribbon cable to a small adaptor board, which
contains a MAX232 chip to invert the serial port signals.
The Vee voltage of the display is connect to pin 6 of the
MAX232.
Detailed design information
about the pushbutton board is now available.
The 80C32 based system on the JW-002 board provides a socketed EPROM
which is mapped only into the 80C32's code space (PSEN signal).
No provision exists to write to the EPROM while it is installed
on the board. There are two 32 kbyte SRAM chips, which are
mapped into data space (RD and WR signals), from 0x0000 to 0xFFEF.
The upper 256 bytes of data space are allocated the memory
mapped peripherals.
The JW-002 board, as purchased from Earth, comes with an OTP
(not reprogrammable) EPROM installed. We believe this is firmware
developed by AT&T to use the display in some sort of phone
terminal that they no longer make. We know very little about
the installed firmware, as the first thing we did was pull their
chip and install a chip with
PAULMON2.
Firmware for the JW-002 board, which implements the protocol
described on this page, can be downloaded from the
firmware download page. Beginning
with 0.6.2.5, the code that needs to run on the JW-002 board
is included in the MP3 player's code distribution. Within the
definitions and comments in that code, you can find information
about what it known about the JW-002 and instructions for a set
of modifications to the JW-002 that allow PAULMON2-based
firmware development (instead of burn-and-learn chip swapping).
Techknowman has reverse engineered the JW-002 LCD board and
drawn a complete schematic diagram. He also has a simple
project that replaces the contrast slider with a
digital contrast control.
Connection Between MP3 Player, Display, and Computer/Terminal
The MP3 player allows both a serial interface display board and a PC
computer to be connected, but is only has a single UART (serial port),
so there are some special considerations needed to allow the MP3
player to communicate with both devices, and to allow the PC to
communicate with the display. When the MP3 player sends a byte, both
the PC computer and display board will "hear" the communication.
When the MP3 player receives a byte, it echo's it, so that whichever
device transmitted it will "hear" it echoed, and the other device will
have an opportunity to "hear" it as well. This allows communication
between the display board and PC.
TODO: draw a diagram
The PC will usually be running a standard terminal emulation program.
Most terminal emulation programs are sensitive to control characters.
Because of this, the commands used to control the display are designed
to avoid containing any control characters, and its responses do not
contain any control characters. This also allow all of the display
capabilities to be "tried" using an ordinary keyboard and terminal
emulation program.
Example Code
Scott Tisdale has provided a
simple Visual Basic program
which demonstrates how to send many of these commands using Visual Basic.
Sending Data To The Display
There are four types of data that can be sent to the display:
- Commands - These are always two or more bytes, beginning with
byte 0x5C (backslash, '\').
- Control Characters and Escape Sequences - These are bytes 0
to 31. Many of these will have special functions, and byte 27
initiates an "escape sequence" where one or more characters
following perform a command. These should not be send from the
MP3 player firmware.
- Character 0xFF - The character 0xFF is special. It, and the
next character that follows it, are always ignored, even within
a command. All communication sent by the display board is
formatted with 0xFF before each data byte, so that it may be
ignored when it is received by the MP3 player firmware's echo.
- Ordinary Characters - Any other character is drawn onto the
display, if the cursor is located within the display area and
the board has not been placed in the "ignore input" mode.
Commands
- Display Backslash '\'
The backslash '\', ascii code 0x5C, begin a command. In order to display a
backslash character, send it twice.
- Transmit:
- 0x5C 0x5C
- Receive:
- nothing
- Display Byte 0 to 31
Some control characters (ascii 0 to 31) have special functions, and it a
PC terminal emulation program is also receiving the communication, it may
respond to control characters. To cause the board to display characters
0 to 31, send a 0x5C followed by the control character plus 32.
- Transmit:
- 0x5C <byte+32>
- Receive:
- nothing
- Display Byte 127
Ascii code 127 should be displayed by sending this command, because a
PC terminal emulation program may respond to this character as a backspace.
- Transmit:
- 0x5C 0x5F;
- Receive:
- nothing
- Display Byte 128 to 159
Characters 128 to 159 should be displayed using these commands, because
some PC terminal emulation programs may have undesirable behavior when
they receive these characters.
- Transmit:
- 0x5C <byte-32>
- Receive:
- nothing
- Ignore Incoming Characters
All non-command characters following this command are ignored and the
image on the display is effectively locked. Control characters and
escape sequences are also ignored, but all commands are still received
and executed. The MP3 player will usually send this command after it
has finished updating the display and needs to send additional information
which is intended to be shown in a PC terminal emulator, but not on the
LCD display.
- Transmit:
- 0x5C 0x5D
- Receive:
- nothing
- Display Incoming Characters
Return to the default state where all non-command characters are drawn
on the screen (if the cursor is within the screen area, of course).
- Transmit:
- 0x5C 0x5B
- Receive:
- nothing
- Clear Display and Set Font
Erase all characters from the display and return the cursor to the
upper left corner. The current font is set to the specified font.
- Transmit:
- 0x5C 0x40 <font+32> 0x30
- Receive:
- nothing
- Show Font Preview Page
Show a font preview page, that shows either the first or second
half of all the characters of a particular font. The current
font is set to whatever font is previews. If the fourth byte
is 0x31, bytes 0 to 127 are shown, and if it's 0x32, bytes 128
to 255 are shown.
- Transmit:
- 0x5C 0x40 <font+32> <0x31 or 0x32>
- Receive:
- nothing
- Set Wrap and Scroll Mode
Line wrap causes the cursor to automatically be repositioned at the
beginning of the next line when it is advanced beyond the end of a
line. When line wrap is off, additional characters are not drawn
until the cursor is manually positioned back into the screen's area.
Scroll mode causes the entire display to scroll vertically when the
cursor is advanced downward beyond the last row of the display. When
scroll mode is off, the behavior is determined by the wrap mode. If
wrap is on and scroll is off, downward cursor movement beyond the
last row causes the cursor to reposition at the top of the screen.
If both modes are off, no additional characters are drawn until the
cursor is manually repositioned into the screen's area.
- Transmit:
- 0x5C 0x41 <mode>
mode = 0x30: wrap off, scroll off
mode = 0x31: wrap on, scroll off
mode = 0x32: wrap off, scroll on
mode = 0x33: wrap on, scroll on
- Receive:
- nothing
- Position Cursor
Set the cursor to an absolute position. The row and column positions
are zero based. For example, to set the cursor to the fourth character
on the second row of the display, 0x5C 0x42 0x23 0x21 would be sent.
- Transmit:
- 0x5C 0x42 <column+32> <row+32>
- Receive:
- nothing
- Select Font
Set the current font. The board supports 32 fonts. Setting to unsupported
fonts will set to font 0 (the default). The font number is offset by
32, to avoid transmitting control characters as part of the command.
- Transmit:
- 0x5C 0x43 <font+32>
- Receive:
- nothing
- Define Custom Character
Download a custom character to RAM. The character number is sent as
two byte ascii hex, followed by a font number (offset by 32), and a
8-byte bitmap. You may write to any font. User defined fonts should
be placed in 8 through 31. Low numbered fonts may also be written,
but this should generally only be done if the appearance of particular
characters needs to be changed. See the
LCD Fonts page for images of the fonts
included in the display board's firmware.
All downloaded font bitmaps are
stored in volatile memory and are lost when the board is rebooted.
- Transmit:
- 0x5C 0x44
<char, 2 byte hex>
<font+32> <bitmap, 8 bytes>
Example: Changing the appearance of capital "R" (R is ascii 0x52) in font #0:
0x5C 0x44 0x35 0x32 0x20 0x3E 0x39 0x39 0x39 0x3E 0x3A 0x39 0x39
Encoded as an ascii string: "\D52 >999>:99"
| Desired Graphic | Bit Encoding | Byte Encoding |
0 0 1 1 1 1 1 0 |
0x3E |
0 0 1 1 1 0 0 1 |
0x39 |
0 0 1 1 1 0 0 1 |
0x39 |
0 0 1 1 1 0 0 1 |
0x39 |
0 0 1 1 1 1 1 0 |
0x3E |
0 0 1 1 1 0 1 0 |
0x3A |
0 0 1 1 1 0 0 1 |
0x39 |
0 0 1 1 1 0 0 1 |
0x39 |
- Receive:
- nothing
- Read Display Board Identification Byte
Ask the board to return a message that will identify it. Other display
boards will return a different code.
- Transmit:
- 0x5C 0x45
- Receive:
- Version 0 - 0xFF 0xC2
- Version 1 - 0xFF 0xC3 "VERSION1"
- Move Cursor Left
- Transmit:
- 0x5C 0x46 <offset+32>
- Receive:
- nothing
- Move Cursor Right
- Transmit:
- 0x5C 0x46 <offset+64>
- Receive:
- nothing
- Move Cursor Down
- Transmit:
- 0x5C 0x46 <offset+96>
- Receive:
- nothing
- Move Cursor Up
- Transmit:
- 0x5C 0x46 <offset+112>
button = 48 to 59
- Receive:
- nothing
- Configure Pushbutton Auto-Repeat Speed
- Transmit:
- 0x5C 0x47 <button> <config+32>
button = 48 to 59
config = (see code)
- Receive:
- nothing
- Configure Pushbutton Message String
- Transmit:
- 0x5C 0x48 <button> <string, 12 bytes>
button = 48 to 59, sets string when pressed (down)
button = 64 to 75, sets strings when released (up)
button = 80 to 91, sets strings for auto-repeat
string = 12 byte string to send, pad with spaces to 12 bytes, all spaces suppresses printing of the string
- Receive:
- nothing
- Cached update or frame buffer control (protocol version 1 and later only)
This feature allows you reduce flicker on the LCD. Rather than having your
characters appear one-at-a-time as they arrive at 19200 baud, you can turn
off instant updates. All your writes are then cached to an off-screen buffer.
Once your entire update is buffered, you send a command to have a
single line or the entire screen quickly updated from the buffer (at the
full bus speed of the LCD controller chips). The redraw commands do not
alter the update mode, and the mode change commands do not cause redraws.
- Transmit:
- 0x5C 0x49 <command>
command = '0' - '7' redraws one line from buffer. Line (0 - 7) specified by command number. Update mode is not changed.
command = '8' redraws entire display from buffer. Update mode is not changed.
command = '9' turns instant display updates on, writes go to buffer and display (default for version 0 compatibility). Please note, this does not cause a redraw of any buffered data. In most cases, a redraw command should be sent together with this one.
command = ':' turns instant display updates off, writes go to buffer only
- Receive:
- nothing
- External input/output control (protocol version 1 and later only)
Control extra IO on CPU. All signals are active low, electrical ground is active '1', electrical 5V is inactive '0'. (refer to Tom's LCD Modification page for more information)
- Transmit:
- 0x5C 0x4A <command> <state>
command = '0' control LED on front panel
command = '1' control pin 7 on CPU (use with care, may crash non-modified hardware)
command = '2' control pin 8 on CPU (use with care, may crash non-modified hardware)
command = '4' read LED on front panel (will turn led off and always read '0')
command = '5' read pin 7 on CPU (will always read '0' on non-modified hardware)
command = '6' read pin 8 on CPU (will always read '0' on non-modified hardware)
state = '0' for inactive (electrical 5V)
state = '1' for active (electrical ground)
(state is ignored for read, but must be supplied)
- Receive:
- "IOREAD" <pin> <state>
pin = '0' LED on front panel (always 1)
pin = '1' pin 7 on CPU
pin = '2' pin 8 on CPU
- Horizontal scrolling control (protocol version 1 and later only)
Horizontal scrolling of lines works by maintaining a 256 byte buffer
for each line. The buffer for a line is filled by enabling buffer
fill, writing characters to the buffer and disabling buffer fill.
When write is enabled for a buffer the buffer for that line is cleared
and scrolling for that line is disabled. When scrolling is enabled
for a line, buffer fill is automatically enabled. ie you can end a
buffer fill just be enabling scrolling for that line. Font and speed
changes are made instantly. The scrolling speed is that same for all
lines.
When scrolling is enabled for a line, all other updates to that line
are ignored. If the cursor moves to a line with scrolling enabled,
all characters will be discarded until the cursor is moved to a
non-scrolling line. Scrolling overwrites the frame buffer data for
each line it is updating.
- Transmit:
- 0x5C 0x4B <command> <data1> <data2>
- command = '0' set the scroll speed -
- <data1> determines the speed ('0' - '7'),
<data2> '0' (ignored, but it must be supplied)
- command = '1' set the font -
- <data1> line number (line+32)
<data2> determines the font (font+32)
- command = '2' enable/disable scrolling -
<data2> determines the scrolling state for this line ('1' is enabled, '0' is disabled)
- command = '3' buffer fill control -
<data2> start/stop buffer fill ('1' is begin filling buffer with input, '0' is stop)
- Receive:
- nothing
- Clear Row (protocol version 1 and later only)
- Transmit:
- 0x5C 0x4C <row_number+32>
- Receive:
- nothing
- Reserved For Custom User-Added Features
These eight codes are reserved for users to experiment with
adding their own features.
They will not be defined in the future on this page.
- Transmit:
- 0x5C <0x53 to 0x57> <2 bytes>
0x5C <0x58 to 0x5A> <8 bytes>
- Receive:
Receiving Events From The Display Board
Control Codes
The board will be able to accept certain control codes, to emulate a
subset of VT100 and other common terminal emulation features. The
MP3 player firmware should not use these control code, and instead
use the commands described above.
- CTRL-A
- Move cursor to home (upper left corner)
- CTRL-H
- Move cursor left
- CTRL-I
- Move cursor to next tab (4 character increments)
- CTRL-J
- Move cursor down
- CTRL-K
- Move cursor up
- CTRL-L
- Clear screen, return cursor to home (upper left corner)
- CTRL-M
- Return cursor to start of current line
- CTRL-U
- Move cursor right
- ESC [ A (up arrow on PC keyboard)
- Move cursor up
- ESC [ B (down arrow on PC keyboard)
- Move cursor down
- ESC [ C (right arrow on PC keyboard)
- Move cursor right
- ESC [ D (left arrow on PC keyboard)
- Move cursor left
