Shopping Cart
| Home | Products | Teensy | Blog | Forum |
You are here:
8051 Tools
LED Blink Program Using The SDCC C CompilerGetting Everything ReadyDownload The SDCC C Compiler Here (free download!), if you do not have SDCC. This LED blink example requires SDCC and GNU Make. The windows SDCC download from this site includes GNU Make. Virtually all linux systems already have GNU Make pre-installed. The description here assumes you are familar with how to communicate with the 8051 development board and download and run programs on it. If you haven't done this yet, the Using The Board For The First Time page explains in detail exactly how to setup communication with the board and download programs to it and run them. Of course, you need to download the LED Blink SDCC source code:
Running The Pre-Built HEX FilesThe blink_c.zip file comes with two ready-to-use intel hex (.HEX) files, called "blink1.hex" and "blink2.hex".As a first step, you should try downloaded one of these to your board and run it. To run the program, use PAULMON2's Jump command (press 'J') and use it to jump to address 2000. Address 2000 is the default if you haven't done any other operations in the monitor which change the current address. When the program runs, you should get a display like this:
The pre-built HEX files are compiled with a "VERBOSE" option that makes them print messages as they run. You should see line after line appear like this:
As the program runs, it checks if you have pressed the ESC key, and restarts the board back to the monitor when it sees that you're pressed ESC.
Making A Simple Change and Compiling With Make & SDCCUsing your favorite text editor, open the "blink1.c" file. This is the main C code that becomes blink1.hex when you compile the code. Other C source files are used as well, but blink1.c is the main one.Inside blink1.c, you'll find the main loop that makes the program run:
The line with the function call to "delay_ms" is what controls the speed of the animation. A simple change to increase the speed of the display is to divide the delay constants, like this:
Once you've made a small change to the program, you will need to recompile the application. Fortunately, this is easy with GNU Make. To recompile the application, just type:
make GNU Make will examine all of the project files, recompile the portions of the project that have changed, and build a new copy of the application. Figures 2 and 3 show what should happen, using both the MS-DOS Prompt in Windows and the Gnome Terminal in Red Hat Linux 7.1. When you download and run the new HEX file, it should display the animation much more rapidly.
BLINK1.C vs BLINK2.C, Different C Coding StylesThe example code includes two different LED blink applications, blink1.c and blink2.c. Blink1.c uses a syntax which may seem simpler if you are new to programming in C, and blink2.c uses a pointer-based syntax which is probably quite familiar if you are an experienced C programmer. This section attempts to provide some explaination of the code in each file. If you are a C expert, there's probably no point to keep reading this section.
Serial I/O Interface With PAULMON2 Monitor RoutinesAs you saw while running the program, messages are printed to the serial port and the application is constantly checking to see if you press the ESC key. There are three basic approaches to using serial I/O:
To use PAULMON2's serial I/O routines, you must include the "paulmon2.h" header file, which provides the ANSI C function prototypes needed to call them. The file "paulmon2.c" contains small C functions which adapt SDCC's calling conventions to the necessary assembly language calling conventions used by PAULMON2's routines. Here is a list of the functions you may call:
You can also use the SDCC C library printf, if you create a "putchar" function. Here is the code to add:
Using Inline AssemblyThe file delay_ms.c contains a simple example of using "inline" assembly language programming from SDCC. This was done partly to demonstrate how to write a function in assembly, and partly because the original blink.asm for AS31 used this same code for a simple delay ;)This example is a simple and unsophisticated software delay using a busy loop. This sort of delay is very simple, but for real applications it is usually necessary to do something while waiting, other than executing NOP instructions. Still, this simplistic example does use several of the basic inline assembly features.
SDCC's inline assembly syntax begins a block of assembly
with SDCC passes the input parameter in DPL. It actually uses DPL, DPH, B and A, in that order, for 8, 16 and 32 bit parameters. This function has a "void" return, but DPL, DPH, B and A are also used when there is a return value. Normally, SDCC assumes that any function it calls will use R0 through R7, so these is no need to save these registers before writing into them. This simple code uses two nested loops, where is runs two NOP (no operation) instructions in the inner loop. The registers R0 and R1 act as loop counters, which are initialized by the two MOV instructions. The DJNZ (Decrement and Jump if Not Zero) counts down the number of times to repeat each nested loop. The RET instruction at the end is actually not necessary, as SDCC will include a return at the end of the function.
Within a function, local labels are defined as
At the top of the code, before the assembly is an unusual
C statement: " Though not shown in the particular example, it is possible for inline assembly to access global variables. The C variable name need a underscore '_' prepended to it when used within assembly. It is also necessary to know what type of memory the variable is stored in, as each type of memory requires different 8051 instructions to access. SDCC does not provide a way to access local variables from inline assembly. Understanding The Makefile and Build ProcedureMost medium and large size C programs are built from several .C files, where each file is compiled separately and then the linker is run to build them together into the final executable. The LED blink example is built this way, partly to demonstrate how this is done, and partly because you might want to reuse the "paulmon2" and "blink_ms" files in other projects.It isn't necessary to become a makefile expert to use a Makefile for your own project. The Makefile in this example was designed to be easy to reuse as a basis for your projects. This section describes how it works, and how you may need to adapt it for a typical project. If you are already familiar with make and Makefiles, you should probably skip this section. The blink example builds two different executables, from blink1.c and blink2.c. Each executable uses the code in delay_ms.c and paulmon2.c. These two files are first built into .rel (relocatable object code) files, and the each executable is created by compiling its C code and linking with the .rel files. Figure 4 shows a diagram of this build process.
When you run make (or MAKE.EXE), the make program reads a file named "Makefile" which contains the instructions that specify how to build the project. It is easy to think about building the project, particularily for a C programmer, as executing a sequence of steps, but this is NOT how the Makefile works. The Makefile specifies the various files that get built, what other files are used to build them, and the command(s) to run. The make program analyzes the structure of your project, looks at the timestamps on the files, and exectutes only the steps required. If your project has many files and only a small number have been changed (the common case), only some portions of the project need to be recompiled. This can really shorten the time required to recompile your project, particularily on a slower computer or when using Windows/MSVCRT (which runs SDCC noticably slower than Linux/GNU_glibc2). Looking at the Makefile, here are the lines that tell make how to build blink1.hex:
The first line specifies that this section will cause "blink1.hex" to be created. The files listed after the colon ':' are the list of files that will be read in the process of creating blink1.hex. Blink1.hex is often called the target and the list to the right of the colon is often called dependencies. This group of lines is called a rule. When speaking about makefiles, people often talk of the rule that is used to build the target from the dependencies. Knowing this lingo will make it easier to ask experts for help with your own Makefile (and conprehend their answers :). When creating a makefiles, usually the most important thing to check is that the all of the required files are specifed in the dependency list. The remaining lines are a list of commands that need to be executed to create blink1.hex. Each command must be indented with a TAB character. This unfortunate syntax can be confusing, so please be careful to use a real TAB character and not 8 spaces. The first command runs SDCC to compile blink1.c and also link the .rel files into the executable. SDCC produces .ihx output files, and the PACKIHX program is used to turn the .ihx files into normal .hex format. The SDCC command uses two variables, SDCCCFLAGS and ASLINKFLAGS. This is just a simple text replacements, which allows these flags to be set in just one place at the top of the Makefile. The rule to build blink1.hex specifies that delay_ms.rel and paulmon2.rel are both needed. Both of those files are built by this rule:
This is what's called an implicit rule, which really only means that it uses special wildcard characters and will be used to build any .rel file that doesn't have it's own explicit rule. This rule specifies that there is a matching .h file for the .c file, which is common practice for including the function prototypes, structure definitions and global variable declarations in both this .c file and other parts of the project which interface with this file's code. Some programmers prefer to create one .h file will all their definitions. If you do this, you would replace the "%.h" with the name of your common header file. With all these various rules, how does make "know" which to build? The answer is that make will strive to build the first non-implicit rule in the file, unless of course you specify the rule you want on the command line. In this Makefile, there is a pseudo rule called "all", which is used to direct make to build more than one output file.
This rule means the nothing needs to be done to build "all", but both blink1.hex and blink2.hex must be built before this "nothing" can be done. When you adapt this Makefile to your own project, you could remove blink2.hex from this rule's dependencies, or just remove this rule alltogether, leaving the rule to build blink1.hex as the first rule. Of course, you would remove the rule for blink2.hex, and rename your project something more interesting than "blink1". As you add more .c and .h files to your project, you would just add them to the dependency list and SDCC command in the rule that builds and links the HEX file. If the list becomes long, you would probably define a variable, like RELFILES and use it in both the dependency list and SDCC command. The Makefile contains one final rule, called "clean", which has no dependencies. Normally this rule will never be executed, because none of the other rules mention "clean" as a dependency. Including a clean rule in the Makefile is a standard convention for specifying a list of commands to delete all the files the compiler, assembler and linker will create that aren't the original source code. The example Makefile uses the unix "rm -f" command, so for windows you would need to replace with the equivilant dos DEL commands or install a RM program. Hopefully this simple introduction and the example Makefile will allow you to make good use of GNU Make for your own SDCC-based projects. Most SDCC-based projects can use this example Makefile with only minor changes. GNU Make is very flexible and has many sophisticated features which can support building very large and complex projects, so as your needs grow, GNU Make will probably be able to accomidate them. There is a complete manual for GNU Make. The manual is also available as a printed book. (TODO: link to where to buy the book...) SDCC Linker Options, Configuring For RAM, FlashTODO: write this part... probably should create a separate memory map page with nice graphics to explain the 8051 memory layout and related issues.
Automatic Start-UpTODO: write tiny AS31 startup to make this application automatically run at restart via PM2 auto-start header. | ||||||||||||||||||||||||||||||||||||||
