Using USB Serial Communication
Teensyduino provides a Serial object which is compatible with the Serial object on standard Arduino boards. Usually Serial is used to print information to the Arduino IDE Serial Monitor.
Serial.begin(9600); // USB is always 12 or 480 Mbit/sec
Serial.println("Hello World...");
delay(1000); // do not print too fast!
Unlike a Arduino Uno & Mega which use slow serial baud rates, the Teensy USB Serial object
always communicates at native USB speed, either 12 or 480 Mbit/sec.
The baud rate setting with Serial.begin(baud) is ignored with USB serial (but it is
of course used with hardware serial).
With Teensy 4.x, a delay is recommended to avoid printing
so quickly that scrolling the serial monitor consumes too much processing
power.
In this example, "Hello World..." is printed once per second.
The Teensy does not actually become a serial device until your sketch is running, so you must select the serial port (Tools -> Serial Port menu) after your sketch begins.
Serial Port Names
In the Tools > USB Type menu, you can select Serial (and many options with Serial), Dual Serial, or Triple Serial.- Serial - Main port for all Serial type
- SerialUSB1 - Second port with Dual Serial and Triple Serial
- SerialUSB2 - Third port with Triple Serial
Standard Serial Functions
All of the standard Serial functions are supported.Serial.begin()
Serial.begin() is optional on Teensy. USB hardware initialization is performed before setup() runs.The baud rate input is ignored, and only used for Arduino compatibility. USB serial communication always occurs at full USB speed. However, see the baud() function below.
Serial.begin() may wait up to 2.5 seconds for USB serial communication to be ready. For fastest program startup, simply do not use this unnecessary function. Its only purpose is for compatibility with programs written for Arduino. The delay is intended for programs which do not test the Serial boolean.
(bool) Serial
Test whether the Arduino Serial Monitor has opened. Normally this is used with a while loop to wait until the Arduino Serial Monitor is ready to receive data.
Serial.println("This may be sent before your PC is able to receive");
while (!Serial) {
// wait for Arduino Serial Monitor to be ready
Serial.println("This line will definitely appear in the serial monitor");
If you will use Teensy in a stand-alone application without the
serial monitor, remember to remove this wait, so your program does
not remain forever waiting for the serial monotor.
Alternately, the wait can be done with a timeout.
while (!Serial && millis() < 15000) {
// wait up to 15 seconds for Arduino Serial Monitor
Serial.print() and Serial.println()
Print a number or string. Serial.print() prints only the number or string, and Serial.println() prints it with a newline character.
// Serial.print() can print many different types
int number = 1234;
Serial.println("string"); // string
Serial.println('a'); // single character
Serial.println(number); // number (base 10 if 16 or 32 bit)
Serial.println(number, DEC); // number, base 10 (default)
Serial.println(number, HEX); // number, base 16/hexidecimal
Serial.println(number, OCT); // number, base 8/octal
Serial.println(number, BIN); // number, base 2/binary
Serial.println(3.14); // number in floating point, 2 digits
On a standard Arduino, this function waits while the data is transmitted. With Teensyduino,
Serial.print() and Serial.println() typically return quickly when the message fits within the
USB buffers. See Transmit Buffering below.
Serial.write()
Transmit a byte. You can also use Serial.write(buffer, length) to send more than one byte at a time, for very fast and efficient data transmission.Serial.available()
Returns the number of received bytes available to read, or zero if nothing has been received.On a standard Arduino, Serial.available() tends to report individual bytes, whereas large blocks can become instantly available with Teensyduino. See Receive Buffering below for details.
Usually the return value from Serial.available() should be tested as a boolean, either there is or is not data available. Only the bytes available from the most recently received USB packet are visible. See Inefficient Single Byte USB Packets below for details.
Serial.read()
Read 1 byte (0 to 255), if available, or -1 if nothing available. Normally Serial.read() is used after Serial.available(). For example:
if (Serial.available()) {
incomingByte = Serial.read(); // will not be -1
// actually do something with incomingByte
Serial.flush()
Wait for any transmitted data still in buffers to actually transmit. If no data is waiting in a buffer to transmit, flush() returns immediately.Arduino 0022 & 0023: flush() discards any received data that has not been read.
Teensy USB Serial Extensions
Teensyduino provides extensions to the standard Arduino Serial object, so you can access USB-specific features.Serial.send_now()
Transmit any buffered data as soon as possible. See Transmit Buffering below.Serial.dtr()
Read the DTR signal state. By default, DTR is low when no software has the serial device open, and it goes high when a program opens the port. Some programs override this behavior, but for normal software you can use DTR to know when a program is using the serial port.
pinMode(6, OUTPUT); // LED to show if a program is using serial port
digitalWrite(6, HIGH); // (active low signal, HIGH = LED off)
while (!Serial.dtr()) {
// wait for user to start the serial monitor
digitalWrite(6, LOW);
delay(250);
Serial.println("Hi there, new serial monitor session");
while (Serial.dtr()) {
Serial.print('.'); // wait for the user to quit the serial monitor
On a standard Arduino, the DTR and RTS signals are present on pins of the
FTDI chip, but they are not connected to anything. You can solder
wires between I/O pins and the FTDI chip if you need these signals.
Serial.rts()
Read the RTS signal state. USB includes flow control automatically, so you do not need to read this bit to know if the PC is ready to receive your data. No matter how fast you transmit, USB always manages buffers so all data is delivered reliably. However, you can cause excessive CPU usage by the receiving program is a GUI-based java application like the Arduino serial monitior!For programs that use RTS to signal some useful information, you can read it with this function.
The Windows USBSER.SYS driver has a known bug where changes made to RTS are not communicated to Teensy (or any other boards using CDC-ACM protocol) until DTR is written. Some programs, like CoolTerm, work around this bug.
Serial.baud()
Read the baud rate setting from the PC or Mac. Communication is always performed at full USB speed. The baud rate is useful if you intend to make a USB to serial bridge, where you need to know what speed the PC intends the serial communication to use.Serial.stopbits()
Read the stop bits setting from the PC or Mac. USB never uses stop bits.Serial.paritytype()
Read the parity type setting from the PC or Mac. USB uses CRC checking on all bulk mode data packets and automatically retransmits corrupted data, so parity bits are never used.Serial.numbits()
Read the number of bits setting from the PC or Mac. USB always communicates 8 bit bytes.USB Buffering and Timing Details
Usually the Serial object is used to transmit and receive data without worrying about the finer timing details. It "just works" in most cases. But sometimes communication timing details are important, particularly transmitting to the PC.Transmit Buffering
On Arduino Uno & Mega, when you transmit with Serial.print(), the bytes are transmitted slowly by the hardware serial to a USB-Serial converter chip.On a Teensy, Serial.print() writes directly into the USB buffer. If your entire message fits within within the buffer memory, Serial.print() returns to your sketch very quickly.
Both Teensyduino and the USB-Serial chip hold a partially filled buffer in case you want to transmit more data. After a brief timeout, usually 3-5 ms in Teensyduino, the partially filled buffer is scheduled to transmit on the USB.
Teensyduino immediately schedules any partially filled buffer to transmit when the Serial.send_now() function is called.
All USB bandwidth is managed by the host controller chip in your PC or Mac. When a full or partially filled buffer is ready to transmit, the actual transmission occurs when the host controller allows. Usually this host controller chip requests data transfer many thousands of times per second, though the timing can be affected by other USB devices consuming a large portion of the available USB bandwidth.
When the host controller receives the data, the operating system then schedules the receiving program to run. On Linux, serial ports opened with the "low latency" option are awakened quickly, others usually wait until a normal "tick" to run. Windows and MacOS likely add process scheduling delays. Complex runtime environments (eg, Java) can also add substantial delay.
Receive Buffering
When the PC transmits, usually the host controller will send at least the first USB packet within the next 1ms. Both Teensyduino and the FTDI chip on Arduino receive a full USB packet (and verify its CRC check). The FTDI chip then sends the data to a standard Arduino via slow serial. A sketch repetitively calling Serial.available() and Serial.read() will tend to see each byte, then many calls to Serial.availble() will return false until the next byte arrives via the serial communication.
// On a serial-based Arduino, bytes tend to arrive one at a time
// so this while loop usually only processes 1 byte before allowing
// the rest of the loop function to do its work
while (Serial.available()) {
// do something with incomingByte
// do other unrelated stuff
time_sensitive_task1();
another_urgent_thing();
still_yet_even_more_stuff();
On a
Teensy, the entire packet, up to 64 bytes on Teensy 2 & 3 at 12 Mbit/sec,
to up to 512 bytes on Teensy 4 at 480 Mbit/sec, becomes available all at once.
Sketches that do other work while receiving data might depend on
slow reception behavior, where successive calls to Serial.available()
are very unlikely to return true. On a Teensy receiving large amounts
of data, it may be necessary to add a variable to count the number of
bytes processed and limit the delay before other important work must
be done.
// On a Teensy, large groups of bytes tend to arrive all at once.
// This bytecount prevents taking too much time processing them.
unsigned int bytecount = 0;
while (Serial.available() && bytecount < 10) {
bytecount++;
When transmitting, Serial.write() and Serial.print() group bytes from successive writes together into USB packets, to make best possible use of USB bandwidth. You can override this behavior using Serial.send_now(), but by default multiple writes are merged to form packets.Microsoft Windows and Linux unfortunately do NOT provide a similar function when transmitting data. If an application writes inefficiently, such as a single byte at a time, each byte is sent in a single USB packet (which could have held 64 or 512 bytes). While this makes poor use of USB bandwidth, a larger concern is how this affects buffering as seen by Serial.available().
The USB hardware present in Teensy can buffer 2 USB packets. Serial.available() reports the number of bytes that are unread from the first packet only. If the packet contains only 1 byte, Serial.available() will return 1, regardless of how many bytes may be present in the 2nd package, or how many bytes may be waiting in more packets still buffered by the PC's USB host controller.
This code will not work on Teensy when the PC transmits the expected 11 byte message in more than 1 USB packet.
// This may not work on Teensy if USB packets have less than 11 bytes!
boolean getNumbersFromSerial() {
while (Serial.available() < 11) { ;} // wait for an 11 byte message
if (Serial.read() == '@') {
time_t pctime = 0;
for(int i=0; i < 10; i++) {
char c = Serial.read();
if (c >= '0' && c <= '9') {
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
pctime += 10;
DateTime.sync(pctime); // Sync clock to the time received
return true; // return true if time message received
return false; //if no message return false
This code can be rewritten to always read a byte when Serial.available() returns non-zero.
// This will always work on Teensy, does not depend on buffer size
int count=0;
char buf[11];
while (count < 11) {
if (Serial.available()) { // receive all 11 bytes into "buf"
buf[count++] = Serial.read();
if (buf[0] == '@') {
time_t pctime = 0;
for(int i=1; i < 11; i++) {
char c = buf[i];
pctime += 10;
Of course, there are always many ways to write a program. The above versions look for a '@' character to begin the message, but do not handle the case where additional bytes (incorrectly) appear before the 10 digit number. It is also not necessary to store the entire message in a buffer, since the work can be done as the bytes are read. Here is a more robust and more efficient version.
// This version is more robust
int count = 0;
time_t pctime = 0;
while (count < 10) {
if (c == '@') {
pctime = 0; // always begin anew when '@' received
count = 0;
count++;
