skip navigational linksPJRC
Shopping Cart Checkout Shipping Cost Download Website
Home MP3 Player 8051 Tools All Projects PJRC Store Site Map
You are here: Teensy Teensyduino Basic Usage Search PJRC
PJRC Store
Teensy, $18
Teensy Pins, $21
Teensy++, $24
Teensy++ Pins, $27
USB Cable, $4
Teensy
Main Page
Getting Started
How-To Tips
Code Library
Projects
Teensyduino
Reference
Basic Teensyduino Usage
The first step is to select the Teensy or Teensy++ from the Tools -> Board menu. If Teensy does not appear in the menu, quit the Arduino Software and install Teensyduino.
Teensyduino uses the Teensy Loader to actually communicate with your board, so make sure the Teensy Loader is running.
The Blink example is a good first test. You can open it with the File->Sketchbook->Digital->Blink menu. The Teensy has its LED on pin 11 (Teensy) or 6 (Teensy++), so you must change the ledPin from 13 to 11 (Teensy) or 6 (Teensy++) . Then click the Verify button to compile this sketch.
When the compile finishes, Arduino will tell you the final size. The Teensy Loader will also automatically update with the sketch name, and Auto mode will activate.
Just press the button on the Teensy.
The Teensy Loader will program your sketch and run it automatically.
Using the Serial Monitor
After your Teensy is running a sketch, you can select the serial port. Unlike an Arduino board with a dedicated USB-serial chip, the Teensy has direct USB hardware (which can be any type of device). Your Teensy does not become a USB serial device until your sketch is running. You can only select the serial port when the Teensy is running a sketch.
When a sketch is running that prints to the serial port, all you need to do is click the Serial Monitor button. The following screenshot shows the serial monitor with the "Sketchbook -> Examples -> Communications -> Graph".
Using the "Upload to I/O Board" Button
You first need to select the serial port, which can only be done while a sketch is running. The first sketch can only be run by using Verify and the pushbutton, as described above.
Then just click the "Upload to I/O Board" button.
After compiling your sketch, Teensyduino will send a command to request the board to reboot. This only works if a previously loaded sketch is still running. If the board can not be rebooted by request, you will get an error message to let you know the pushbutton must be pressed. If it does work, the Teensy Loader will automatically program and run your sketch.
In the normal course of trying ideas, editing code and running each change, clicking the Upload to I/O Board button normally works, and is one less step than having to also press the pushbutton on the Teensy.
