Arvind Singh (forum user vindar) made an amazing acoustic levitator.
An acoustic levitator uses sound waves to levitate small objects, and until a few years ago were expensive to construct using Langevin horns that required tight tolerances and operate at high voltages. Asier Marzo from Bristol University published a paper demonstrating how an acoustic levitator can be constructed from off the shelf parts and run on low-voltage.
Arvind built a levitator from an Instructible project based on an Arduino Nano, then decided to improve upon it by building one with a Teensy 3.2. The processing power and memort of the Teensy 3.2 allowed for additional options to be added such as a TFT display and a joystick.
The casing was 3D printed using wood PLA then stained and varnished making for a beautiful device.
Code, schematics, and STL files are available on Git Hub.
