Soldering Pins on to Your Teensy
We published a video on with some tips on soldering header pins on to your Teensy board.
A couple of tips to remember when soldering header pins to your board:
1 – You MUST solder the pins.  Setting the Teensy on the header pins without completing the soldering will not work.
2 – Use a breadboard to keep the pins straight and stable when soldering
3 – Leave the soldering iron on the pad for a moment after you solder.  This will bring all the components – the pad, the header pin, and the solder up to the same temperature so they will cool together to form a proper molecular bond.
The Pool Interactive LED Art Installation
The team a Jen Lewin Studios created an amazing interactive LED art installation called The Pool that is best described as an environment of giant, concentric circles created from interactive pads.
The Pool uses thousands of LEDs driven by Teensy boards to create pools of light you can run and jump and play in.
This video shows the beautiful interactive nature of The Pool and Jen Lewin talks about her inspiration for the installation.
PETT Plant
John Van Strien and team have created an interactive light and sound responsive sculpture called PETT Plant.
This beautiful work of art can be programmed custom animations from and Android app.  It also has a sound responsive mode where the color of each stem modulates like a rainbow graphic equalizer.
PETT Plant also comes pre-programmed with several brainwave entrainment sequences.  In entrainment mode, PETT Plant will pulsate at specific frequencies to help move you into brainwave states conducive to inducing sleep, meditation or increasing alertness.
This video shows the PETT Plant in action
Thunder Mansion
Thomas Hudson and a group of people at the Oregon Museum of Science and Industry (OMSI) have gotten into the Halloween spirit early with this freaky shaking haunted mansion.  The house is made of cardboard with some miniature skulls, bats, and cats laser cut out of plastic.  Thomas added lightning and sound effects as well as making the house shake.  This spooky house is an awesome prop to kick off the Halloween season.
This video shows the mansion in action
Thomas has made the code available on GitHub.
Video Wall
Wolfgang Höhne submitted his video wall project that he recently made.  The field where his football club plays it can be difficult to know the score and time remaining.  Wolfgang created a video wall to display this information.  It’s remotely updated by the announcer to keep spectators informed on the game.  Not every field is equipped with large signboards to display match information.  This project is a great way to solve that problem.
There’s a good write up of the project, including the code, over on Hackster.io.
Phantom Limb Bionic Arm
Adrian Godwin submitted the Phantom Limb, a robotic prostetic arm created by The Alternative Limb Project and game company Konami.
The design for the arm was inspired by the world of Metal Gear Solid.  The arm is a elegant and beautiful design and is a far cry from many of the common prosthetic designs we are used to seeing. Adrian let us know that a Teensy 3.2 is used in the arm to handle lights, comms, and power control.
This video tells the story of how the arm came to be and an interview with James Young, the gentlemen wearing the arm.
