Few people are able to distinguish between a flu and a cold based on symptoms alone, but what if a device could do it for you? F°LUEX is an automated medical diagnostics device that uses the Teensy 3.2.
Designed by engineer and actual rocket scientist M. Bindhammer, F°LUEX is an automated medical diagnostics device that incorporates a medical-grade MLX90614 infrared thermometer to read human body temperature with an accuracy of ±0.2˚C. Following the reading, the patient is asked a series of questions displayed on an OLED screen about their symptoms. Based on their temperature reading and the patient’s responses which are input using the device’s controls, the thermometer is able to distinguish cold from flu within a certain probability based upon the same Bayesian statistic analysis process that is frequently used among modern medical practitioners. The device is powered by two 1.5 V AA alkaline batteries and all electronics including display, inputs (soft power switch and miniature joystick), and sensor are driven by a Teensy 3.2.
M. Bindhammer created the project to support his 8 year old daughter who frequently contracts the flu and whose pediatrician is often unavailable on the weekends when she usually becomes ill. In his design, he strove to use only a few easy-to-obtain components in combination with a 3D printed case so that others could replicate the project at home. The project is a winner of a 2020 Hackaday Prize and the full project description can be viewed on Hackaday.
