Mingjing Huang has developed the LEDoctopus, an expansion board to make developing your LED projects easier.
The LEDoctopus I/O expansion board makes it easy to get started on LED projects – no soldering required. All you need is to plug in your Teensy, with pins; up to 8 WS281x LED strips using standard terminal blocks; and 5V power using a standard barrel connector. You can also use USB power through the Teensy. Or if you have a high power application, the board includes a place to add a connector rated up to 45A. Once you have everything plugged in, you’re ready to start using the OCTOWS2811 library to control your LEDs
This board is available on Tindie.
