SimpleRick is a low-cost DIY 2D ultrasound imaging hardware project designed by William Meng.
SimpleRick makes innovative use of Software Defined Radio, pairing it with an ultrasound transducer to make a maker-friendly, affordable ultrasound imager. It works by sending out acoustic sound waves and then listening for audio bouncing back from objects in the path of the waves.
Meng’s project is based on an open hardware ultrasound project called un0rick. For SimpleRick, Meng replaced the more expensive specialist components in un0rick with a Teensy and Software Defined Radio.
Meng has written up the SimpleRick project and released the hardware design files and code under the TAPR Open Hardware License over on his GitHub, where you can also find an overview of the system architecture and some great experiment logs.
