Step 2, Resistors, Crystal, Small Capacitors
Step 2, Component List
Quantity | Color | Components |
4 | Red | Resistor, 4.7 Ohm, Yellow - Violet - Gold - Gold |
2 | Blue | Resistor, 162 Ohm, Metal Film, Brown - Blue - Red - Black - Brown |
2 | Green | Resistor, 1K Ohm, Brown - Black - Red - Gold |
3 | Yellow | Resistor, 8.25K Ohm, Metal Film, Gray - Red - Green - Brown - Brown |
1 | Orange | Resistor Network, 22K Ohm, 8 Lead Bussed, Marked "223" |
1 | Violet | Capacitor, 22 pF, Ceramic Disc, NPO |
2 | Brown | Diode, 1N4148 |
1 | Cyan | Crystal, 7.3728 MHz |
Step 2, Notes
The 22K resistor network must be inserted with pin 1 facing the top of the board.
The 12 ohm resistor from step 8 looks similar to the 1K resistors. Double
check the order of the brown and red bands, as installing a 12 ohm resistor
in this step could lead to damaged chips.
Hi-Res Images Available
These eleven assembly diagrams are also available as high resolution
TIFF files that will look better when printed.
