Step 10-B, Power Supply: Transformer and Chips
Step 10-B, Component List
Quantity | Color | Components |
1 | Red | IC, TPS2814, MOSFET Driver |
1 | Blue | IC, TL5001, PWM Controller |
1 | Green | Transformer, VP4-0060 |
1 | Yellow | Transistor, NDS8434, P-Channel Mosfet |
Step 10-B, Notes
The NDS8434 P-Channel MOSFET is mounted on the bottom side of the board under
the TIP102 transistor. The side with pin 1 should face the screw that mounts
Hi-Res Images Available
These eleven assembly diagrams are also available as high resolution
TIFF files that will look better when printed.
