Shopping Cart
| Home | Products | Teensy | Blog | Forum |
You are here:
OSU8 Microprocessor
ALU-8 Function Decode LogicThe 8-bit ALU requires may internal control signals. This simple two-level AND/OR circuit produces all of those signals, from a four bit input which corresponds to the 4-bit operand used in all of the instructions which use the ALU. For any of the 16 operations, this logic determines which parts of the ALU will process the 8-bit register data. To understand why this circuit asserts each signal, please see the detailed description of the ALU circuity works.
