Shopping Cart
Home | Products | Teensy | Blog | Forum |
You are here:
OSU8 Microprocessor
P2 Pointer RegisterThis is the 16-bit register that holds OSU8's P2 pointer register. Either of two sources can load the register, depending on the state of SLEB, and the upper and lower 8-bit may be separately enabled by ENL and ENH.
