USB Host Cable For Teensy 3.6 or Teensy 4.1
SparkFun is now manufacturing Teensy products. You can buy directly at SparkFun.
CABLE_USB_HOST_T36 USB Host Cable, For Teensy 3.6 & 4.1
This short cable allows connecting a USB device, or a USB hub to Teensy 3.6 or Teensy 4.1.
Teensy 3.5 & 3.2 are not supported. While Teensy 4.0 has USB host capability on bottom-side pads, this cable does not mate directly with Teensy 4.0. Only Teensy 3.6 and 4.1 have the pads for a 5 pin header to mate with this cable.
To use this cable, you will also need to solder pins to Teensy 3.6 or 4.1.
The overall length is approx 8 inches (20 cm). The portion that is flexible cable is approx 5.5 inches (14 cm).
Teensy 3.6 / 4.1 and pins are sold separately.
