Pins (header), 14 pins, 0.1 inch (2.54 mm) spacing, Double Insulator
Out Of Stock HEADER_14x1_D Pins (header), 5 pins, 0.1 inch (2.54 mm) spacing, Double Insulator $0.85
Inventory Status:Out Of Stock
Last physical count:Mar 9, 2025
This special 14 pin header has two insulators, which makes it very easy to solder the Audio Adaptor to a Teensy 3.0 or 3.1 board. Two headers are needed.
