Pins & Socket for Teesny 4.1 Ethernet, 6 pins, 2 mm spacing
SparkFun is now manufacturing Teensy products. You can buy directly at SparkFun.
HEADER_SOCKET_3x2 Pins (header) and Socket, 6 pins, 2 mm spacing
Recommended Accessories: Pins 24x1 (2), Sockets 24x1 (2)
These pins and socket are meant to connect Teensy 4.1 ethernet to a custom circuit board, which Teensy 4.1 is used with the normal sockets and pins.
They are sold together as a pair.
The socket is intended to solder to the bottom side of Teensy 4.1.
The mating pins are then soldered to your custom PCB.
When Teensy 4.1 is plugged into the sockets, these 6 pins for Ethernet mate properly. The distance between the boards is approximately 11 mm.
Dimensions
PA = 8.5mm
PC = 2.8mm
Overall Length = 13.3mm
Alternate part numbers have been discussed on the forum, if you wish to buy from Digikey or other electronics distributors.
