Teensy 4.1 Development Board
SparkFun is now manufacturing Teensy products. You can buy directly at SparkFun.
TEENSY41_PINS | Teensy USB Board, Version 4.1, With Ethernet Chip, With Pins Soldered (Ethernet connector kit sold separately) |
TEENSY41_NE_PINS | Teensy USB Board, Version 4.1, Without Ethernet Chip, With Pins Soldered |
Recommended Accessories: USB Cable, 8MB PSRAM, USB Host Cable, Ethernet Kit
Teensy 4.1 features the fastest micocontroller and an expanded set of
powerful peripherals in a 2.4 by 0.7 inch form factor.
Teensy 4.0 can be programmed using the Arduino IDE with Teensyduino add-on.
Technical Specifications Compared to Teensy 4.0
Teensy 4.1 & 4.0 use the same IMXRT1062, so most technical specifications are the same.Please refer to the Teensy 4.0 page for common specifications and features.
| Feature | Teensy 4.1 | Teensy 4.0 |
| Ethernet | 10 / 100 Mbit DP83825 PHY (6 pins) | -none- |
| USB Host | 5 Pins with power management | 2 SMT Pads |
| SDIO (4 bit data) | Micro SD Socket | 8 SMT Pads |
| PWM Pins | 35 | 31 |
| Analog Inputs | 18 | 14 |
| Serial Ports | 8 | 7 |
| Flash Memory | 8 Mbyte | 2 Mbyte |
| QSPI Memory | 2 chips Plus Program Memory | Program memory only |
| Breadboard Friendly I/O | 42 | 24 |
| Bottom SMT Pad Signals | 7 | 16 |
| SD Card Signals | 6 | 0 |
| Total I/O Pins | 55 | 40 |
Pinouts
Teensy 4.1 is designed to bring all general purpose I/O pins to breadboard friendly pads on the outside edges.
Ethernet
To use the Ethernet port, a magjack and capacitor need to be connected.This is currently available only as a DIY project using this OSH Park Shared Circuit Board. PJRC is planning to offer this as a DIY kit in the near future. You can also make the connection by soldering wires.
These parts are recommended to build the Ethenet connection.
1 Ethernet Magjack RB1-125BAG1A, Mouser 950-RB1-125BAG1A, Digikey 1278-1011-ND 2 Header, 3x2, 2mm pitch Digikey 1849-1000-ND 2 Socket, 3x2, 2mm pitch Amphenol FCI 89361-706LF, Digikey 609-3139-ND 1 Ribbon Cable, 3 to 6 inch Digikey HF06S-5-ND 1 Capacitor, 0.1uF, 805 1 Capacitor, 1uF, 805 probably not needed 1 Capacitor, 1nF, 805 optional, should be high voltage rated if used 1 Resistor, 1M optional 1 Circuit Board OSH Park Shared PCB
Memory Expansion
The bottom side of Teensy 4.1 has locations to solder 2 memory chips.
The smaller location is meant for a PSRAM chip. The larger location is intended for flash memory.
USB Host
Teensy 4.1's USB Host port allow you to connect USB devices, like keyboards and MIDI musical instruments. A 5 pin header and a USB Host cable are needed to be able to plug in a USB device.
USB hubs may be used if more than 1 device is needed. See the USBHost_t36 examples for details.
