DmxSimple Library
DmxSimple, by Peter Knight, allows you to control up to 512 DMX lighting dimmers.
Download: Included with the Teensyduino Installer
Latest Developments on Github
DmxSimple only transmits. Ward's code can receive DMX on Teensy 3.0.
A serial-based DMX library for Teensy 3.x with Transmit & Receive is now available.
Another serial based DMX library is also now available with direct hardware access & optimized buffering.
This MIDI to DMX Instructable may also help, for efficient transmit-only code on Teensy LC, 3.2, 3.5 or 3.6.
Hardware Requirements
TODO: document connections, show photos - Andy confirms it works (Teensy++ only)... need to find someone local with a DMX dimmer pack so I can test and take a good photo.
Basic Usage
DmxSimple.write(channel, brightness);
Set the DMX channel (1 to 512) to brightness (0 to 255)
Example Program
/* Welcome to DmxSimple. This library allows you to control DMX stage and
** architectural lighting and visual effects easily from Arduino. DmxSimple
** is compatible with the Tinker.it! DMX shield and all known DIY Arduino
** DMX control circuits.
** DmxSimple is available from: http://code.google.com/p/tinkerit/
** Help and support: http://groups.google.com/group/dmxsimple       */
/* To use DmxSimple, you will need the following line. Arduino will
** auto-insert it if you select Sketch > Import Library > DmxSimple. */
#include <DmxSimple.h>
  /* The most common pin for DMX output is pin 3, which DmxSimple
  ** uses by default. If you need to change that, do it here. */
  DmxSimple.usePin(3);
  /* DMX devices typically need to receive a complete set of channels
  ** even if you only need to adjust the first channel. You can
  ** easily change the number of channels sent here. If you don't
  ** do this, DmxSimple will set the maximum channel number to the
  ** highest channel you DmxSimple.write() to. */
  DmxSimple.maxChannel(4);
  int brightness;
  /* Simple loop to ramp up brightness */
  for (brightness = 0; brightness <= 255; brightness++) {
    /* Update DMX channel 1 to new brightness */
    DmxSimple.write(1, brightness);
    /* Small delay to slow down the ramping */
    delay(10);
Details
Please visit the official DmxSimple web page for detailed information.
