skip navigational linksPJRC
Shopping Cart Checkout Shipping Cost Download Website
Home MP3 Player 8051 Tools All Projects PJRC Store Site Map
You are here: Teensy Teensyduino Libraries Wire Search PJRC
PJRC Store
Teensy, $18
Teensy Pins, $21
Teensy++, $24
Teensy++ Pins, $27
USB Cable, $4
Teensy
Main Page
Getting Started
How-To Tips
Code Library
Projects
Teensyduino
Reference
Wire Library
The Wire library allows you to communicate with I2C devices, often also called "2 wire" or "TWI" (Two Wire Interface).
Download: Wire is included with Arduino
Hardware Requirements
I2C devices communicate with 2 signals, called SDA and SCL. Normally a 4.7K pullup resistor is connected between each signal and +5 volts. For short wires to only 1 device, you may not need these resistors.
SignalTeensy 2.0Teensy++ 1.0Teensy++ 2.0
SCLPin 5Pin 0Pin 0
SDAPin 6Pin 1Pin 1
The Wire library is not compatible with Teensy 1.0.
Basic Usage
Wire.begin()
Begin using Wire in master mode, where you will initiate and control data transfers. This is the most common use when interfacing with most I2C peripheral chips.
Wire.begin(address)
Begin using Wire in slave mode, where you will respond at "address" when other I2C masters chips initiate communication.
Transmitting
Wire.beginTransmission(address)
Start a new transmission to a device at "address". Master mode is used.
Wire.send(data)
Send data. In master mode, beginTransmission must be called first.
Wire.endTransmission()
In master mode, this ends the transmission and causes all buffered data to be sent.
Receiving
Wire.requestFrom(address, count)
Read "count" bytes from a device at "address". Master mode is used.
Wire.available()
Retuns the number of bytes available by calling receive.
Wire.receive()
Receive 1 byte.
Responding in Slave Mode
Wire.OnReceive(myReceiveHandlerFunction)
Causes "myReceiveHandlerFunction" to be called when a master device sends data. This only works in slave mode.
Wire.OnRequest(myRequestHandlerFunction)
Causes "myRequestHandlerFunction" to be called when a master device wishes to read data. This only works in slave mode.
Example Program
This simple example uses a 24C256 I2C EEPROM. The first byte is read, incremented, and written back.
#include <Wire.h>
  Wire.begin();
  byte num;
  // set the 24C256 eeprom address to 0
  Wire.beginTransmission(80);
  Wire.send(0);  // address low byte
  Wire.send(0);  // address high byte
  Wire.endTransmission();
  // read 1 byte, from address 0
  Wire.requestFrom(80, 1);
  while(Wire.available()) {
    num = Wire.receive();
  Serial.print("num = ");
  Serial.println(num, DEC);
  // increment num
  num = num + 1;
  // write "num" to 24C256 eeprom at address zero
  Wire.send(num);  // any more send starts writing
  // next time loop runs, it should retrieve the
  // same number it wrote last time... even if you
  // shut off the power
  delay(5000);
Using Addresses
Many datasheets will document I2C addresses as 8 bit numbers including a R/W bit. Here is an excerpt from the AT24C256B datasheet, the chip used in the example above.
The Wire library requires addresses which do not include the R/W bit. Based only on the datasheet, you might conclude the address is 160 when writing and 161 when reading. The Wire library needs address 80 to communicate with this chip. The R/W bit is automatically created based on your use of the send or receive functions.
More Details
Please refer to the official Wire library documentation for more details.
