skip navigational linksPJRC
Shopping Cart Checkout Shipping Cost Download Website
Home MP3 Player 8051 Tools All Projects PJRC Store Site Map
You are here: Teensy Teensyduino Libraries Stepper Search PJRC
PJRC Store
Teensy, $18
Teensy Pins, $21
Teensy++, $24
Teensy++ Pins, $27
USB Cable, $4
Teensy
Main Page
Getting Started
How-To Tips
Code Library
Projects
Teensyduino
Reference
Stepper Library
The Stepper library allows you to connect stepper motors, which move in small individual steps that makes slow and precise movement easy.
Download: Stepper is included with Arduino
Hardware Requirements
Stepper is compatible with all Teensy boards. Stepper can control unipolar or bipolar stepper motors. In this photo, Stepper is controlling a unipolar stepper motor salvaged from an old Teac 5¼ inch floppy disk drive.
Small stepper motors designed for 5 volts may be able to run from power provided by USB. Larger motors will require separate power.
Basic Usage
Stepper mystepper(steps, pin1, pin2, pin3, pin4);
Create an instance of the Stepper library for a unipolar type stepper motor. You will need to create an instance for each motor, giving each motor a unique name of your choice.
Stepper mystepper(steps, pin1, pin2);
Create an instance of the Stepper library for a bipolar type stepper motor.
Movement Control
mystepper.setSpeed(rpm);
Sets the speed, in rotations per minute.
mystepper.step(number);
Move the motor 1 or more steps. The number can be positive or negative, to specify the direction of movement.
Example Program
This example is a slightly modified version of MotorKnob, which can be opened from the File -> Examples -> Stepper menu.
/*  MotorKnob - slightly modified
 * A stepper motor follows the turns of a potentiometer
 * (or other sensor) on analog input 0.
#include <Stepper.h>
// the number of steps on your motor
#define STEPS 200
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
Stepper stepper(STEPS, 7, 9, 8, 10);
// the previous reading from the analog input
long previous = STEPS / 2;
  // set the speed of the motor to 30 RPMs
  stepper.setSpeed(30);
  // get the sensor value.  This equation maps the
  // analogRead range to the number of steps, so the
  // motor nicely tracks a potentiometer's position
  long val = (long)analogRead(0) * STEPS / 1024;
  // move a number of steps equal to the change in the
  // sensor reading
  stepper.step(val - previous);
  // remember the previous value of the sensor
  previous = val;
Unipolar Stepper Motors
TODO: info about unipolar type motors
TODO: schematic for circuit in photo above (2N3904 transistors, 1N4936 diodes, 1K resistors)
TODO: how to identify the common wire using a multimeter, and trial-error to get the windings sorted out
Bipolar Stepper Motors
TODO: info about bipolar type motors
TODO: suggested schematic using an "easy" H-bridge chip
TODO: how to identify each winding usine a multimeter
More Details
Please refer to the official Stepper library documentation for more details.
