skip navigational linksPJRC
Shopping Cart Checkout Shipping Cost Download Website
Home MP3 Player 8051 Tools All Projects PJRC Store Site Map
You are here: Teensy Teensyduino Libraries SoftPWM Search PJRC
PJRC Store
Teensy, $18
Teensy Pins, $21
Teensy++, $24
Teensy++ Pins, $27
USB Cable, $4
Teensy
Main Page
Getting Started
How-To Tips
Code Library
Projects
Teensyduino
Reference
SoftPWM Library
SoftPWM, written by Brett Hagman, can create additional PWM outputs on any pin. The signal frequency is relatively slow (default 30 Hz), which is mostly useful for controlling the brightness of LEDs.
Download: SoftPWM.zip - Modified to work with Teensy 2.0
Hardware Requirements
SoftPWM can control up to 16 pins. Any digital pin may be used.
TODO: photo: board with 5 RGB LEDs
SoftPWM is compatible with Teensy 2.0 and Teensy++ 1.0 & 2.0.
TODO: table showing which pins are no longer available as normal PWM. Teensy 2.0: pins 10 & 12. Teensy++ 1.0: pins 1 & 24. Teensy++ 2.0: pins 1 & 24.
Basic Usage
TODO: write this
Example Program
TODO:
CPU Usage & Interrupt Latency
SoftPWM uses a timer and interrupt routine, which consumes considerable CPU time.
TODO: actually measure CPU usage (maybe try changing the number of channels...)
Latency sensitive libraries, like Servo and NewSoftSerial, will likely be disrupted by SoftPWM.
More Details
Please refer to the official SoftPWM documentation for more details.
