skip navigational linksPJRC
Shopping Cart Checkout Shipping Cost Download Website
Home MP3 Player 8051 Tools All Projects PJRC Store Site Map
You are here: Teensy Teensyduino Libraries SoftwareSerial Search PJRC
PJRC Store
Teensy, $18
Teensy Pins, $21
Teensy++, $24
Teensy++ Pins, $27
USB Cable, $4
Teensy
Main Page
Getting Started
How-To Tips
Code Library
Projects
Teensyduino
Reference
SoftwareSerial Library
Do Not Use
SoftwareSerial
NewSoftSerial corrects the problems present in SoftwareSerial.
Download: SoftwareSerial is included with Arduino
Known Problems
SoftwareSerial does not handle interrupts properly. Any interrupts, from the normal timer0 (used for millis, delay, micros) to any other libraries in use, can cause corrupted data.
SoftwareSerial has poor timing, with incorrect hard-coded assumptions about the speed of digitalWrite. On Teensy, the maximum working baud rate is 19200.
SoftwareSerial does not support available(), and can only receive data when read() is called, which severly limits its usefulness for many applications.
If you do use SoftwareSerial, the transmit pin is not set to output mode automatically. You must use pinMode to set it.
As of June 2010, the Arduino developers are considering replace SoftwareSerial with NewSoftSerial in some future version (0019 or later). They may rename NewSoftSerial to SoftwareSerial at that time.
Example Program
/*  SoftwareSerial example (modified for Teensy++ pin numbers)
  http://arduino.cc/en/Reference/SoftwareSerialExample
  Sample of the SoftwareSerial library.  Listens for serial in on rxPin
  and sends it out again on txPin.
  by Tom Igoe
  based on examples by David Mellis and Heather Dewey-Hagborg
  written: 6 Jan 2007
// include the SoftwareSerial library so you can use its functions:
#include <SoftwareSerial.h>
#define rxPin 27
#define txPin 0
#define ledPin 6
// set up a new serial port
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
byte pinState = 0;
void setup()  {
  // define pin modes for tx, rx, led pins:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello World - SoftwareSerial");
  // listen for new serial coming in:
  char someChar = mySerial.read();
  // print out the character:
  mySerial.print(someChar);
  // toggle an LED just so you see the thing's alive.
  // this LED will go on with every OTHER character received:
  toggle(ledPin);
void toggle(int pinNum) {
  // set the LED pin using the pinState variable:
  digitalWrite(pinNum, pinState);
  // if pinState = 0, set it to 1, and vice versa:
  pinState = !pinState;
Details
For more details, please refer to the official SoftwareSerial page.
