skip navigational linksPJRC
Shopping Cart Checkout Shipping Cost Download Website
Home MP3 Player 8051 Tools All Projects PJRC Store Site Map
You are here: Teensy Teensyduino Libraries X10 Search PJRC
PJRC Store
Teensy, $18
Teensy Pins, $21
Teensy++, $24
Teensy++ Pins, $27
USB Cable, $4
Teensy
Main Page
Getting Started
How-To Tips
Code Library
Projects
Teensyduino
Reference
X10 Library
X10 allows you to send control messages to X10-based AC power line control devices.
Download: x10.zip (version 0.4)
This library supports transmit-only communication. Receiving status and 2-way communication is not available.
Hardware Requirements
You will need a PSC04 (pdf) or similar X10 powerline interface.
Connecting the PSC04 is easy, using a RJ-11 connector (same a telephone). The center two wires are ground, and the other 2 just connect any pins. Pin details below.
Basic Usage
x10 myHouse = x10(zeroCrossPin, dataPin);
Create the x10 object with a name of your choice, using the 2 pins where you connected the signals. While you could create multiple x10 objects, in practice there's no reason to do so unless you have completely separate electrical systems! A single X10 transmitter will send to all X10 devices attached to the same AC power line.
myHouse.write(house, unit, numTimes);
Select a specific X10 device to receive communication.
house may be A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, or P.
unit may be UNIT_1, UNIT_2, UNIT_3, UNIT_4, UNIT_5, UNIT_6, UNIT_7, UNIT_8, UNIT_9, UNIT_10, UNIT_11, UNIT_12, UNIT_13, UNIT_14, UNIT_15, or UNIT_16
numTimes specifies the number of times to send this message.
myHouse.write(house, function, numTimes);
Send a command to a X10 device
function may be ALL_UNITS_OFF, ALL_LIGHTS_ON, ON, OFF, DIM, BRIGHT, ALL_LIGHTS_OFF, EXTENDED_CODE, HAIL_REQUEST, HAIL_ACKNOWLEDGE, PRE_SET_DIM, EXTENDED_DATA, STATUS_ON, STATUS_OFF, or STATUS_REQUEST. Functions which affect a single unit will control the unit previously selected with above write using UNIT_X. Some of these functions involve 2-way communication, which can't be used with this x10 library that only supports transmitting.
Normally messages only need to be sent once, but numTimes may be set to 3 if you suspect noise or interference may be corrupting some of your messages.
Example Program
#include <x10.h>
#include <x10constants.h>
const int zeroCrossPin = 2;
const int dataPin      = 3;
// set up a new x10 instance:
  Serial.println("Lights on:");
  myHouse.write(A, UNIT_1, 3);
  myHouse.write(A, ON, 3);
  Serial.println("Lights off:");
  myHouse.write(A, OFF, 3);
Connector Pinout & Wiring
PSC04 Power Line Interface
PSC04 PinSignal
1Zero Crossing Detect
2Ground
3Ground
4Data
When the Zero Crossing Detect signal should be connected to a pullup resistor (the libary enables the built-in pullup), the signal should have a 60 Hz square wave. If measured with a voltmeter in DC mode, it should measure approximately 2.5 volts, or half of the power supply voltage.
Version 0.4
Version 0.4 enables the built-in pullup resistor. Prior versions of this library required you to connect a resistor, but with 0.4 you may just connect the Zero Crossing signal directly to any pin.
Other minor improvements in code efficiency were also added in 0.4.
Details
More information may be found at the Original X10 Library page.
